78 Biarritz Trunk Pull Down / Release
Started by fellenzer, October 08, 2018, 07:43:24 PM
fellenzer
Greetings.
Trying to help a buddy.
Been searching the archive and not having any luck. Has anyone ever added the trunk pull down/release to a 78 Eldorado? Yes, a well-optioned Biarritz and it doesn't have the trunk option.
Appreciate any guidance.
Thanks.
Michael Fellenzer, #30007
Indianapolis, IN
1976 Eldorado Convertible
1976 Fleetwood Sixty Special Brougham (EFI, ACRS)
1976 Coupe deVille (Astro/Cabriolet)
1984 Seville
1989 Fleetwood Coupe
1989 Sedan deVille
1992 Fleetwood
1992 Coupe deVille
1992 Sedan deVille
1993 Sixty Special (Ultra)
1994 Fleetwood Brougham
2015 SRX
Possible, you would need all the donor parts.  Wire up a switch, doesnt have to be oe.
TMoore - NTCLC
I think that the auto-release will be a relatively easy addition, and you can likely find everything that is necessary in a salvage yard.  The auto pull-down will be a bit more of a challenge since, if I recall correctly, the stationary catch for the cars that are not equipped with auto pull down is tack welded to the body (I could be wrong, but I seem to recall considering this addition to a car once, and decided that it was going to entail more effort than it was worth - to me)
