331 Head Identification
Started by dfc1, October 15, 2018, 01:44:13 AM
dfc1
Hi, New member here.  I'm having a problem identifying some Cadillac heads that I acquired.  I have 4 heads all together.  2 of them have casting numbers of 1465406-7.  From what I can find I think they are '56 or '57 331 heads.  The other number I have 1454022-3.  I can't find anything on this number.  Any help would be appreciated.
D.Caldwell
1950 Cadillac
1941 Cadillac
D. Caldwell
dfc1
Does anyone have a 331 head casting chart.  I can't find a year for this number 1454022-3.
Thanks in advance.
D. Caldwell
1950 Cadillac
1941 Cadillac
D. Caldwell
I have an interchange manual with casting numbers. According to that book, the number 1454022 was for heads used from 1949 to 1953. the book has also 3 other different casting numbers for 49-53 heads.
Jay Friedman
There were 2 different cylinder heads used in 1949:
  a. early heads are set up for valve covers held on with 2 bolts in the middle of the valve cover;
  b. late heads heads are set up for valve covers held on with 4 bolts at the periphery of the valve cover.
I think the same late '49 heads were used in '50 and '51 too.
As I understand it, 1952 and '53 heads have larger exhaust valves and exhaust ports.
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
dfc1
Thanks Roger and Jay.  This is exactly the info I was looking for.  I appreciate it.
Doug
1950 Cadillac
1941 Cadillac
D. Caldwell
