1937 LaSalle Fuel Sending Unit
Started by CadDad, November 07, 2018, 05:59:21 AM
CadDad
 Hello,
  Got my fuel sending unit out of my gas tank and sent it out. Been 2 months now with a lot of double speak from the re builder. They say I need to be patient. My mechanic is about to put my car outside due to such a wait. I have looked online for fuel senders along with looking all over this forum. Some say Pontiac and Buick are the same for this year. I have sent out quite a bit of stuff for rebuilding and repair and only have this one item left.  Everything else is done and ready to go. Any suggestions? Thanks, Paul
1955 Series 62 2dr. hardtop
1959 Buick LeSabre 2dr. with  Manual transmission
1949 International Harvester KB-1
1977 Oldsmobile Cutlass Supreme
1941 Buick Century Sedanet
1941 Packard 110 Club Coupe
1937 LaSalle Opera Coupe
1940 Ford Deluxe Coupe
Chris Bryant #19358
Hello,
Google TANKS.COM and buy one of their 80 ohm sender units. Cheap and instantly available. Make sure you get the correct pattern of screws and you can adjust the float mechanism to suit your tank. 80 ohms is compatible with your fuel gauge.
Cheers,
Chris Bryant #19358
PS: I've just done this on my 38 Cad 60S and make sure that you are careful when inserting the unit that it does not get hung up on the interior of the tank because you will always have the same reading!
CadDad
 The only issue is that mine has the pick up tube built in.
harvey b
That is the same problem i am having with mine,its a 60 series cad,basically a fancy lasalle that year,i have been looking for one about 10 years now and have never seen one >:(,rare as hens teeth,a one year only part too,if you come up with a solution id love to hear it. Harveyb
Harvey Bowness
Used on most GM of that year if that helps.
CadDad
 My sender unit guy called last night to tell me it was done and ready to be shipped. I was doing quite the happy dance! There we several items on this LaSalle I hope never to have to find again!
