1937 LaSalle How To Remove Speedometer
Started by suchan, December 14, 2018, 06:06:17 PM
suchan
I tried to get at the speedometer to remove it for repair from behind the dash, and was able to remove two of the screws before my back said no more. I'm too big and too old. I'm assuming the dash needs to be removed to get at the speedo?
Southworth, Washington
CLC #28060
1937 LaSalle 5019 Sedan
Cars that got away:
1930 Ford Model A Roadster and AA Flatbed
(2) 1938 Buick Sedans
1942 Chev Blackout Coupe
1953 Ford F100
1955 Ford Victoria
1956 Sedan DeVille
1962 Peugeot 403
1965 Peugeot 404
1971 Eldorado Convertible
suchan
CLC #28060
Cars that got away:
1953 Ford F100
1955 Ford Victoria
1956 Sedan DeVille
1962 Peugeot 403
1965 Peugeot 404
harvey b
It will come out without removing the dash,there are 4 bolts holding it in,2 on the top and 2 on the bottom side,.It is not getting it out that is the most fun,wait until you try and put it back in,then the fun begins,as me how i know. :P Good Luck  Harveyb
Harvey Bowness
harry s
Mr  Anthenien, I was thinking about you today when I was under the dash of my '41 hooking the power feed for the turn signals to the gas gauge. It wasn't too bad getting into position but trying to figure out how to get out was a challenge to a taller, older guy. Fortunately I had all the right tools, etc. Some time the braille method works if you can be sure you are on the right connection.       Harry
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
suchan
I agree with Harvey B, replacing the speedo will be the trick. Lots of wires back there, many more than the '38 Buicks I had.
CLC #28060
Cars that got away:
1953 Ford F100
1955 Ford Victoria
1956 Sedan DeVille
1962 Peugeot 403
1965 Peugeot 404
