1937 LaSalle water pump leak
Started by Cadillac Jack 82, December 15, 2018, 01:27:26 PM
Cadillac Jack 82
So I've been combing over my new 37 when I noticed I have a very very small puddle of antifreeze on my concrete.  At first I thought this was the overflow but it appears my water pump has a small leak from the impeller shaft.  Its not leaking badly but it worries me for long cruises.  Is this a common issue with these and what is the fix?  Remove the water pump and replace a seal?
Tim
CLC Member #30850
1959 Cadillac CDV "Shelley"
1964 Cadillac SDV "Rosalie"
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1955 Packard Clipper
1957 Cadillac Series 62
1962 VW Bug
1962 Dodge 880
1966 Mercury Montclair
1968 Chevy Chevelle SS
1968 Plymouth Barracuda
1977 Lincoln MKV
DaveZ
Hi,
   My opinion, there may be other advice out there. First try adding some water pump grease. It has to be water pump grease as it has wax in it. Regular grease is no good. Older cars has a grease cup on it and 37 just had a fitting to be used with a gun for water pumps. We always remove the fitting and put a grease cup on it that you can turn down occasionally. If that doesn't not work you will need to remove pump and replaces seals etc. They have two kinds of kits out there. Original type and new and improved. Don't over tighten the belt as it places a lot of stress on the water pump bushing.
David Zitzmann
1932 345B
harry s
...to add to Dave's advice if you elect to use a gun with the fitting in place be sure it is a manual low pressure and only give on shot and not until the grease shows as when doing chassis. Good Luck,     Harry
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
Jim Miller
Following on Harry's comment, I actually take the fitting out and push the water pump grease in with my finger. Too much pressure with a gun, it will leak.
Jim Miller
1941 6219
1949 6237X
1970 CDV
2021 XT6
Past:
1991 SDV
1999 DeElegence
2006 DTS
2013 XTS
2016 SRX
