How does the fuse block mount? 1956 62 series
Started by RayRay, December 26, 2018, 07:21:08 AM
RayRay
I have a picture of the location but can't figure how it mounts. I must be missing a backing plate or something. I removed all of the sound deadening material and it still isn't clear to me how it mounts.
Thanks in advance!
J. Gomez
Quote from: RayRay on December 26, 2018, 07:21:08 AM
Thanks in advance!
Ray,
You are missing the firewall insulator pad inside the cabin, there are two slots cut which the fuse box will mount, those will be just behind the glove box.
Good luck..!
J. Gomez
CLC #23082
RayRay
Quote from: J. Gomez on December 26, 2018, 08:55:30 AM
Ray,
Good luck..!
Perfect, now everything else that mounts to the firewall also makes sense. Thank you for that valuable info!
