2001 Cadillac Eldorado ETC Molding Water Leak
Started by DaveN, January 05, 2019, 09:31:13 AM
DaveN
I have an issue with a water leak that my Auto-body shop indicates is coming from the replaced passenger side door. This window also has wind noise when driving. Years ago this window had wind noise and the window was adjusted and molding replaced. I understand the window has up/down and side to side adjustments that can take some time. Molding p/n 25699283 is not available any longer and have been struggling to find the part. Does anyone know where to get molding?
Ideally, the OEM p/n 25699283 or a universal equivalent? I see Steele Rubber products has a catalog with universal molding, but do not know what the correct p/n would be?
Thanks any help would be appreciated.
