Bowen cable
Started by spolij, January 11, 2019, 10:12:52 PM
spolij
A Bowden cable is a type of flexible cable used to transmit mechanical force or energy by the movement of an inner cable relative to a hollow outer cable housing. Does anyone know how to clean this? I pulled the inside cable and cleaned it then ran alcohol thru it then wd40 still hard to pull the cale. Took it apart ran mineral spirits thru. Really dirty fluid came out. lubricated it and put it back together. Still very stiff. This cable is for the cruise control.
Mike Josephic CLC #3877
Sounds like the same type of assembly that a
speedometer cable uses.  Are you sure that the
cable and the shroud have no kinks in them
someplace?  That's what normally ruins a speedo
cable unit.
1955 Cadillac Eldorado
1973 Cadillac Eldorado
1995 Cadillac Seville
2004 Escalade
2011 Buick Lucerne CX
CLCMRC Museum Benefactor #38
Glen
The more common name that I am familiar with is “choke cable”.  The inside does not rotate but slides in and out.  They must have large smooth bends.  If the bend it too tight it becomes too hard to move the cable.
Glen Houlton CLC #727
CLCMRC benefactor #104
#3
Keep cleaning it and try soaking the whole thing in PB Blaster.  Maybe coil it up in a large ziplock bag?  It will start to move again.
Chris Bryant #19358
Hi folks,
Why not go to your local motorcycle shop and buy a cable oiler kit? They are cheap and you can use it on all sorts of Bowden cables.
Chris Bryant #19358
spolij
Glen and Mike You are correct. A friend and i held it straight after it was lubed and it was still tough to move.
Thanks 76eldo
Chris I'll check that out. Nothing like more tools. lol
