1962 Factory a/c?
Started by 6caddy2, January 21, 2019, 03:01:01 PM
6caddy2
Does anybody know if they are making or have made the foam gasket for the a/c heater box?!? this would the foam gasket which is in between the box and the firewall where it mounts, have to replace 2 of the vacuum actuators that have done there job well after 56 yrs of service, so the box has to come off the firewall to do this and I know with my luck that gasket isn't going out without a fight  >:( :(!! Any leads or advice on this matter I would greatly appricate!
        Joe clc#29214
1962 convertible
1979 Fleetwood brougham d'Elegance
1981 Coupe deVille 368 FI 864
1996 Fleetwood Brougham
SOLD- 1978 sedan deVille
6caddy2
Got it Art, thanks for the heads up, yes the heater core has been done, should've done the vacuum actuators then >:( :o ::), live and learn! thanks again! Joe
1962 convertible
David Greenburg
Old Air Products probably has that gasket.
David Greenburg
'60 Eldorado Seville
'61 Fleetwood Sixty Special
