Chrome Trim around windows. Help!
Started by hokethompson, January 31, 2019, 02:02:55 PM
hokethompson
Hello again.
how on EARTH do I get these off without destroying them.
72 Fleetwood window chrome trim pieces.
picture attached...
-Hoke Thompson
jagbuxx #12944
Probably screwed on but you’ll need to remove the weather strip for access . Best to review the Fisher Body manual
Frank Burns #12944
61 Coupe Deville Bristol Blue
41 Series 61 Deluxe Coupe 6127D Black
08 STS 3.6 1SC  Thunder Gray
16 GTI Gray
03 T-Bird Black
19 Tiffin Phaeton 40AH
07 Corvette Blue
20 MB S450 White
"Whatever the occasion, there
is no better way to arrive than in a Cadillac.
Ralph Messina CLC 4937
Hoke,
I assume that's the rear window. In '66 the trim was held on with spring clips that attach to studs welded into the window channel. There's a flat blade tool with a hook that's slid under the trim to release the clip. Previously, you mentioned a friend in the body repair business. He may be able to give you a quick tutorial. If you see it done and see the clips, you'll have a better feel of how to do it yourself. Try not to damage the clips. They're are still available but getting harder to find. The windshield is similar.
HTH
2018 GMC Yukon
