1956 Cylinder head casting numbers
Started by SedanDeville, February 01, 2019, 07:11:59 AM
SedanDeville
Hello!
I wonder what casting numbers 1956 cylinder heads has.
I know that there is early castings that's prone to crack and later redesigned castings that doesn't crack so easily.
Please can somebody help me with the casting numbers of the early and later 1956 cylinder heads?
Thanks in advance!
Best regards
David
J. Gomez
Quote from: SedanDeville on February 01, 2019, 07:11:59 AM
Hello!
Thanks in advance!
Best regards
David
Dave,
There are several posts regarding your topic on the '56 heads, below are a few from the search, there are more but these are the latest;
http://forums.cadillaclasalleclub.org/index.php?topic=151354.0
http://forums.cadillaclasalleclub.org/index.php?topic=100942.msg110471#msg110471
http://forums.cadillaclasalleclub.org/index.php?topic=149288.msg389511#msg389511
HTH
J. Gomez
CLC #23082
SedanDeville
Quote from: J. Gomez on February 01, 2019, 07:56:13 AM
Dave,
HTH
Thanks, but I wrote those threads yesterday and I couldn't find the casting numbers for the early heads.
Best regards
David
J. Gomez
Quote from: SedanDeville on February 01, 2019, 11:21:27 AM
Best regards
David
David,
If you checked the first link that post has a lengthy details regarding the ’56 heads which Clay (aka lexi) has done an extensive research on them.
There are a few threads indicating the early ’56 casting were Left - 1465406-7 Right - 1462983-4 (still inconclusive data on the 1462983-4) while other thread shows the L and R having the same casting 1465406.
HTH
J. Gomez
CLC #23082
