'61 - '62 upper support arm bushings
Started by James Landi, February 08, 2019, 08:02:02 AM
James Landi
Based on your experience, what is the approximate "service life" of the upper support arm bushings of the 1961-62 model year Cadillac, as it relates to the odometer reading/miles driven?   Thanks for your input.   James
Rubber bushings fail generally due to age, temperature of environment, heat cycles (short trips heat them and they cool down as opposed to highway trips), and of course mileage.  I had a 1970 SDV (on a 1962 vs 1970 it might be same part number), and at 45 years old and 35k miles they were completely gone and I replaced them.
I would say any 1970's or older car, all the rubber suspension parts (and most all other rubber parts) should be replaced if you plan to drive it much - trailer queen with only parking lot driving they can remain.
Good news is 1962 Cadillac is last year of the 1981 and earlier V-8's with steel timing chain cam sprockets (in lieu of nylon coated aluminum) and so timing chain does not automatically need to be replaced.
