1956 Eldorado Seat track - Help
Started by bladepro2000, February 11, 2019, 11:46:45 PM
bladepro2000
I took apart my seat track a few years ago and restored all the wiring, solenoids, etc. Judging by the diagrams I've seen,  I know how to position both the rear support brackets that hold the side panel in place, but for the life of me I cant remember if they bolt in between the seat and track sandwiched in, or directly under the track. Any help would be greatly appreciated. I attached a pic of the support brackets. Thanks
Pasquale Ferro
J. Gomez
Quote from: bladepro2000 on February 11, 2019, 11:46:45 PM
If the channel ears are pointing upwards as it shown on the MPL, the support would be between the track and seat. The seat underframe has a bump at both ends were the bolts are place, so it looks like the support channel would slide in and held by the seat underframe from twisting around.   ???
Just a guess maybe someone with this seat arrangement can validate.
Good luck..!
J. Gomez
CLC #23082
bladepro2000
Yes Mr. Gomez, I was thinking the same thing...I just wanted to be sure. I know your a pro at this since you responded to Chuck Dykstra's post reguarding the same issue some time ago. Thanks again
Pasquale Ferro
J. Gomez
Quote from: bladepro2000 on February 12, 2019, 01:02:11 PM
You are quite welcome..!   ;)
Just remember my good friend Mr. Chuck Dykstra is a troublemaker, just as FYI.  ;D
J. Gomez
CLC #23082
bladepro2000
Pasquale Ferro
