2014 Cadillac CTS Suspension Advisory
Started by CadOwnerSix, February 19, 2019, 09:07:27 PM
CadOwnerSix
I wanted to let all of you who might own a 2014 CTS, that there is a potential that you may get a suspension advisory. My CTS had this problem as there are no service bulletins on this. My Cadillac dealership service center, after much searching, found the problem to be a too short of a left front lower control arm wiring harness. The technician said Cadillac did not mount it properly when they installed it, which caused it to stress and eventually break. The replacement harness was $60.15, but because their was no service bulletin on it, the technician ended up spending $330 worth of labor to find the problem and fix it. I have submitted a letter to the Cadillac Customer Service Center recommending they put out a service bulletin on this as the Standard of the World should not have a wiring harness defect due to manufacturing on a five year old car!
