Founded 1958
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Forum Rules
Calendar
Login
Register
CLC Home
Forum Rules
Technical / Authenticity
(Moderators:
Lars Kneller 8246
quadfins
Barry M Wheeler #2189
Bill Hedge CLC 14424
1939 Lasalle series 50 stearing column
All Cads
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: 1939 Lasalle series 50 stearing column (Read 578 times)
fbouchal
on:
March 01, 2019, 04:51:59 PM »
Hi,
I am missing some parts on my Lasalle but I don't know what I am looking for. Does anyone have a diagram of the column. I have enclosed a picture of my column to show what I have. Any help is greatly appreciated. Thanks Frank
Logged
Name: Steve Passmore - Sadly Deceased
Re: 1939 Lasalle series 50 stearing column
Reply #1 on:
March 01, 2019, 05:16:35 PM »
I don't see anything missing there. There weren't any indicators in the column until 1940 so it looks the same as 38 in there. Why do you think somethings missing?
Logged
39LaSalleDriver
Reply #2 on:
March 01, 2019, 11:14:05 PM »
Sounds like you have the same problem I had when I first got mine. In your engine compartment where the steering column comes through the firewall there are two curved arms on the column. Those attach to the "Shifter Connecting Arms". One controls the 1st and Reverse gears and if it's in the wrong position you can't move the lever on the steering wheel. Just stick your hand in there and move it up or down to the correct position and you should be okay. I freaked out when it first happened to me because I had mine parked in gear and couldn't even crank the engine. Apparently, I had knocked it out of position while I was fooling around under the hood the day before. I was scared I had seized the engine up as it was bitterly cold out and I hadn't checked the antifreeze yet
Last Edit: March 02, 2019, 04:16:47 AM by USNTar
Logged
Jon Isaacson
(formerly USNTar)
1939 LaSalle 5019
fbouchal
Reply #3 on:
March 05, 2019, 03:12:35 PM »
Thanks for the replys. I found the issue. The brass collar wasnt all the way in the shadt so the lever wasnt seated down all the way. I just got the car and am finding lots of little issues. 🤔
Logged
fbouchal
Reply #4 on:
March 05, 2019, 04:47:26 PM »
Hi Art
I am not sure i didnt have to unbolt mine from the dash i just had to remove the shifter.
Logged
harvey b
The truth is often a bitter pill to swallow
Reply #5 on:
March 06, 2019, 07:45:24 AM »
wont drop down much,maybe 1/2 inch if lucky,the steerting colum is part of the steering box,it sticks straight up.Had same issue on my 37,just use lots of tape and paper. Harveyb
Logged
Harvey Bowness
39LaSalleDriver
Reply #6 on:
March 06, 2019, 08:35:28 AM »
Harvey is correct, not much play in there. I had my dash out when I painted mine so it was a lot easier to access.
Logged
Jon Isaacson
(formerly USNTar)
1939 LaSalle 5019
Print
Pages: [
1
Go Up
« previous
next »
(Moderators:
Lars Kneller 8246
quadfins
Sitemap
1
2
3
4
5
6
7
8
9
10
11
12
13
All Cads
