Identifying ‘59 or ‘60 p/s pump
Started by David Greenburg, March 03, 2019, 02:33:12 PM
David Greenburg
I had always understood that the p/s pumps on these cars were the same or at least interchangeable, but the MPL shows 2 different numbers, and I’m trying to confirm the identity of a spare pump I picked up many years ago. But I don’t see any number on the pump, at least without removing the reservoir. Are there visual differences that can help determine what I’ve got?
David Greenburg
'60 Eldorado Seville
'61 Fleetwood Sixty Special
David King (kz78hy)
David,
Looks like the 2 are for air suspension and non air suspension.  The non air suspension has a different P/N between '59 & '60,  I'm almost certain that either would work.
The photos have the info in them.
David
David King
CLC 22014  (life)
1958 Eldorado Brougham 615
1998 Deville d'Elegance
1955 Eldorado #277
1964 Studebaker Commander
2012 Volt
CLCMRC benefactor 197
59-in-pieces
David,
I agree with the other David, that the pumps are the same except for the attaching of the air compressor.
And although the latter has 2 bolts, you only need plug one and move on, at least that is what I have been told, but no personal knowledge.
Have fun,
Steve B.
S. Butcher
Skwerly62
David I just pulled mine off and rebuilt it today here are a few pictures. It is a 1960 without air-conditioning. I am just realizing it should have been painted black, oops.
1958 Extended Deck 62 Sedan SOLD
1960 Coupe - current project
USCG Vet - Fly CG!
60eldo
  They are different, the 59, the in fluid hose is on the outer side of the pump or if ur looking at the pump from your fender, 60 is on the inner, toward the engine
Jon. Kluczynski
Skwerly62
Correct, the 60 pressure hose is inboard closer to the head, the non pressure hose outboard closer to the fender.
USCG Vet - Fly CG!
David Greenburg
Thanks, all.  I've been traveling and away from my garage, but this will enable me to confirm what I've got.
David Greenburg
