7/8" Sway Bar Bushings for 1967
Started by MikeLawson, April 03, 2019, 07:08:36 PM
MikeLawson
I recently replaced the sway bar bushings on my 1967 DeVille and I found the part that everyone lists as correct for this application is actually wrong. The sway bar diameter is 7/8" and the bushings listed by Moog and others are only 3/4".  The Moog part # is K5243 but this will get you bushings that are too small. After doing some research, I found 7/8" sway bar bushings from Energy Suspension. Their part # is 9.5108.  The bushings are black polyurethane and they are well made and the set includes new brackets which fit perfectly in place of the originals.
DeVillain
 I plan on changing the sway bar bushings on my 67 too. Now I know which part to get. Thanks
