C52 19847 What year Cadillac
Started by jyinger, May 02, 2019, 01:36:54 PM
jyinger
What year Cadillac for this transmission?
Jon Yinger
Jeff Hansen
Jeff Hansen
1941 6019S Sixty Special
1942 7533 Imperial Sedan
Bob Schuman
The C52 tells it is a 1952 Cadillac transmission, not a commercial chassis model. The rest of the number is the transmission serial number. Should be a good one to use in your 42.
The 41 had the selector detents in the selector head, 46 and later had them in the transmission, not sure about 42. If using a later transmission the detents in the indicator on the column need to be disabled.
Bob Schuman, CLC#254
2023 XT5
