Good call, gentlemen. It is the shocks. Now, keep air shocks or go gas charged? Disabling that level control is mighty tempting.
Interesting. I have had a lot of cars with air shocks and I assume at some point I must have let them sit fully extended. Apparently I have always had air in em. So the air shocks must have some sort of internal check valve sort of thing in them that gets stuck so when they start with no pressure then suck air in when they get fully extended the air becomes trapped? No more air in or out?Or is is something like the air bag gets folded over and jammed mechanically? Or is there something different about the shock part and it has nothing to do with the air section other than something about the air section changes the design of the shock section?
