1956 Cadillac Windshield Washer Problem-Help needed
Started by johnregrus, May 10, 2019, 10:42:58 AM
johnregrus
I need some advice.
My 56 Cadillac is on its way to the Grand Nationals and the only thing I can't seem to fix is the windshield washers. It will not spray washer fluid onto the windshield.
I see air bubbles in the washer jar when I press the washer button on the dash. The washer jar and lid is new old stock and has never been installed on a car.
What do you think could be wrong?  Thanks for any help you could provide.
1958 Series 62
J. Gomez
Quote from: johnregrus on May 10, 2019, 10:42:58 AM
I need some advice.
John,
Is the fluid line or the nozzles block?  If you disconnect the fluid supply line from the pump, do you see fluid squirting out from the pump?
The pump itself has a very low pressure so a blockage on either it or the line could revert the fluid back into the bottle.   ;)
Good luck..!
J. Gomez
CLC #23082
I bet that it's the vacuum seal which is not sealing properly in the large cylinder (see the arrow). Remove the plunger and have a look at this rubber seal. Maybe with massage and silicone past you can make it good again.
The washer system on the picture is not exactly what you have: this is a Continental Mark II washer, similar to the 1955 Cadillac system. The vacuum part is identical to yours.
carguyblack
Roger,
Weren't you the one that also suggested years ago that the vacuum junction (on the firewall)  diaphragm gasket might be another source of failure in these systems? Maybe John's visual symptoms are different than mine were.
Chuck
Chuck Dykstra
1956 Sedan DeVille
1956 Coupe DeVille (2 sold)
1957 Oldsmobile 98 (sold)
1989 Bonneville SSE
Yes, it was me. However, if the vacuum manifold is not functioning properly, it does not deter the windshield washer.
