1939 Reveal Molding Removal
Started by LaSalle5019, May 19, 2019, 10:22:59 PM
LaSalle5019
The stainless steel reveal molding on my 1939 LaSalle snaps over the pinch weld. It looks straight forward to remove but I thought I would check if there were any tricks before I start. Thanks for the help.
Scott
Brad Ipsen CLC #737
If this is original and has not been off before or if it was installed many years ago, heat up the molding with a heat gun.  The sealant used between it and the pinch weld will be hard as a rock but it will soften with heat.  Go easy as it can be bent if too much force is used.  When reinstalling use 3M 08509.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
1940 Cadillac 60S Limo
LaSalle5019
Thanks for the tip Brad. I do have a tube of the 3M for the rest of the windshield install.
Scott
