1960 Zinc Plating
Started by oregonjam, May 23, 2019, 12:37:03 PM
oregonjam
Just sharing information.
I restored my hinges and bolts using a local zinc plater. They charge $25 per rack and will plate anything that fits on the rack for that price. I had both hinges, all the bolts, front hold down and engine vacuum lines done on one rack. The hinges were plated and then  yellow chromate dipped all assembled with the springs removed.
After this I started plating in my garage on my own. pretty simple with household items other than buying a yellow chromate concentrate.
pics below. Hopefully this helps some of you in need of restoring parts.
Cheers,
John
Cheers,
John Miller
1960 Series 62 Coupe
1954 Oldsmobile Rocket 88
1968 Camaro SS
1968 C10 SWB Pickup
1976 Bronco Sport
gouldsom
Your results look impressive,  can you give me some more  details on your set up as I would also like to be able to zinc my own parts.
Thanks Richard
