1968 transmission kickdown switch
Started by Rocketdoc, May 24, 2019, 06:48:13 PM
Rocketdoc
Does anyone have a picture of the 1968 Cadillac Deville (472) transmission switch and carb connection  linkage (installed) Im trying to piece together the proper set up!
A few pics are worth 1000 words!!
DeVille68
Here are two pictures.
Hope it helps.
If you are not after complete 100% originality, you could insert a micro switch to do the task.
When these transmissions were used in Australia, they put the switch onto the accelerator pedal, inside the passenger compartment, but then, we used a throttle cable instead of the rod linkage.
The 1969-77 GM Cars TH400 Kickdown Switch - GM 1242101 is still
available new, check Evil Bay.  This was used on 68 Toronado with the
rod linkage, by adding a mount on the pedal assembly.  Works well
on every car here.  Bruce Roe
Rocketdoc
Thanks the info and Pics very helpful!!
