Author Topic: 1959 Cadillac brake lights  (Read 1027 times)
Offline Billharrison
  • Name: Bill Harrison
« on: May 27, 2019, 05:03:41 PM »
While driving my 1959 Series 62 this weekend I was told that my brake lights and turn signal lights were only working intermittently. Ive never had any electrical system issues with this car before so wondering if it could be a fuse , a wiring problem or something more complex.
1959 Cadillac Series 62 Flat Top
1964 Cadillac Eldorado
1966 Cadillac Fleetwood Brougham
  • Name: Eric DeVirgilis
Re: 1959 Cadillac brake lights
« Reply #1 on: May 27, 2019, 05:07:45 PM »
Possibly bad ground but could be a lot of things. I doubt fuse because either it's bad or it isn't.
Both pairs of taillights or just on one side?
Offline TJ Hopland
« Reply #2 on: May 27, 2019, 05:13:09 PM »
I would not rule out the fuse.  They are cheap and easy.   Some of the older fuses used a sort of cement to hold it all together and after many years it gets loose so you could have a loose connection and corrosion going on.
StPaul/Mpls, MN USA
73 Eldo convert w/FiTech EFI
80 Eldo Diesel
90 CDV
Offline Dan LeBlanc
  • Name: Dan LeBlanc
« Reply #3 on: May 28, 2019, 07:11:55 AM »
Possible corrosion in the bulb socket could be a culprit too.
Dan LeBlanc
« Reply #4 on: May 28, 2019, 11:33:35 AM »
Both lights on both sides.
Offline savemy67
  • Name: Christopher Winter
« Reply #5 on: May 28, 2019, 01:34:09 PM »
Hello Bill,
A couple of things come to mind.  Since it is both lights on both sides, I would look for something common in that circuit.  I am not sure if the '59 had an adjustable stop light switch.  If it does, the switch may be at the point where it may or may not function correctly given brake pedal travel.  These switches make contact with the brake pedal.
That said, a stop light switch would not affect the turn signals, so, back to something in common with the tail lamp wiring harness like a loose ground.  If the tail lamps are grounded through the body sheet metal, the sheet metal has to be grounded in such a way that the circuit can be completed through to the battery, so a possible loose ground may be no where near the tail lamps or tail lamp wiring.
Respectfully submitted,
Christopher Winter
Christopher Winter
1967 Sedan DeVille hardtop
Offline Dan LeBlanc
  • Name: Dan LeBlanc
« Reply #6 on: May 28, 2019, 01:48:33 PM »
If I recall correctly, the turn signals and brake lights are all fed through the turn signal switch in some way or another.
Remember having a 61 awhile ago that I had to jiggle the turn signal switch to get the brake light to come on at the driver's side.  That could be another starting point.
Dan LeBlanc
« Reply #7 on: May 28, 2019, 02:13:11 PM »
I had two '59s where the turn signal needed to be exercised a bit to get the LEFT brake/turn signal lamps to work. The rights always worked and all 4 parking lamps always worked. However this is different from the situation here since all 4 of the lamps are affected.
« Last Edit: May 28, 2019, 04:50:12 PM by Eric DeVirgilis CLC# 8621 »
« Reply #8 on: May 28, 2019, 04:20:41 PM »
Thanks All, good suggestions. I appreciate the direction.
Offline JayRudig390
  • Name: James
« Reply #9 on: May 28, 2019, 05:24:12 PM »
I just had the exact same issue....turn signal switch wiring was the issue in my case.  The brake light circuit runs through the turn signal switch.
Offline Skwerly62
  • Name: C. Ives
« Reply #10 on: June 04, 2019, 03:36:12 PM »
Agreed, I am rewriting
MY 60 right now and all taillight functions run through the turn signal switch in the column. (Except park aka running lights). I would say ground second.
1958 Extended Deck 62 Sedan SOLD
1960 Coupe - current project
USCG Vet - Fly CG!
