74 Eldorado Convertible window relay
Started by PersianLimeFiremist, May 27, 2019, 06:06:53 PM
PersianLimeFiremist
The shop manual for my 74 Eldorado convertible does not show any information regarding relays for the power windows. I'm guessing that's in the body manual, which I thought I had, but can't find. My left front door window does not operate at the switch but the switch tests as good and the motor works when you jump the terminals. I have a friend who was an electrician and he is convinced there are window relays. Any help? Thanks, Bob
1959 Coupe DeVille, 1960 Series 62 Coupe, 1963 Series 62 Coupe, 1971 Sedan DeVille, 1974 Eldo Convertible, 1996 Fleetwood Brougham, 1969 Fleetwood Brougham, 1981 Fleetwood Brougham Station Wagon by ACC
