Interesting that you have shoulder belts. Required for Oz? My car doesn't even have them on the front.
I can make a solid model of it for you if that would help. You could 3D print it then.
Thanks Mitchel,I need to make one that is a bit stronger than factory, as the factory ones seem to be broken very easily.John is sending me the measurements, so that should be perfect.Bruce.
