Founded 1958
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Forum Rules
Calendar
Login
Register
CLC Home
Forum Rules
General Discussion
(Moderators:
Lars Kneller 8246
quadfins
Barry M Wheeler #2189
Bill Hedge CLC 14424
1979 thru 1985 Eldorado A pillar rust
All Cads
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: 1979 thru 1985 Eldorado A pillar rust (Read 463 times)
e.kempton
on:
June 16, 2019, 04:56:39 PM »
I am wondering what is the cause of the rust that is found on the lower A pillar of many 1979 thru 1985 Eldorados I have seen over the years? It is mostly on the right hand pillar at the bottom close to the windshield. Even the nicest rust free car could have this problem. Is there a fix so it will not happen again? Any thoughts on this problem?
Logged
Administrator
CLC Number: 2189
Re: 1979 thru 1985 Eldorado A pillar rust
Reply #1 on:
June 17, 2019, 11:09:31 AM »
I believe that this is caused by a sound deadening material slipped inside the A pillar. You have to remember that GM only made these cars with a shelf life of 10 years. Luckily, my 1981 Seville with the same construction spent twenty years in storage so I haven't had a problem with mine.
Logged
Barry M. Wheeler #2189
1981 Cadillac Seville
1991 Cadillac Seville
goob
Name: gary grieshaber
Reply #2 on:
June 17, 2019, 11:48:05 AM »
Up here in the northeast, those things would rot out when they were 2 or 3 years old. I used to split the pillar and dig out as much of the sealer / sound deadener as possible, then repair the damage I created. Ah...the good old days!!
Logged
TMoore - NTCLC
Reply #3 on:
June 17, 2019, 12:41:56 PM »
Is the car has a sun roof, I believe the drain tube runs down the passenger side A-pillar. Check to make sure that the hose is not blocked or leaking.
Logged
Reply #4 on:
June 26, 2019, 08:34:35 AM »
I would point out, the rust proofing of cars has never involved
those pillars. If you remove the moulding, you see this bare
metal. If there is any kind of windshield leak, it rusts fast. I
have considered doing a treatment there myself. Bruce Roe
Logged
Print
Pages: [
1
Go Up
« previous
next »
General Discussion
(Moderators:
Lars Kneller 8246
quadfins
Sitemap
1
2
3
4
5
6
7
8
9
10
11
12
13
