Author Topic: Finding a qualified mechanic for a 1976 Eldorado Convertible  (Read 723 times)
Offline Maxfli
  • Name: Clinton Dunlop
I live in Sunset Beach, NC and am looking for a mechanic to work on three issues with my Eldorado. The interior lights will not go out, the gas gauge is nonfunctional, a new sending unit was installed but the mechanic was unable to find the ground wire so the unit doesn't work, and to inspect the ride leveling system and make it functional. I bought the car in November with 440 miles on it and it currently has 750 miles on it. Everything else on the car now works properly but would feel much better if someone who members trusted and were happy with went over the car completely. Any recommendations?
Offline Scot Minesinger
Re: Finding a qualified mechanic for a 1976 Eldorado Convertible
« Reply #1 on: June 17, 2019, 03:20:09 PM »
"the mechanic was unable to find the ground wire"  If ever there was a crazy statement that is it.  Grounds are easy to make anywhere you need them.
Sorry about my rant and I see why you need to find a good mechanic.  The best mechanic you will eventually find is yourself.  Reading the manual and gradually doing everything myself was the best way.  I bought my 1970 DVC with the idea of paying others to work on it, but never could find anyone and decided to do it all myself.  After about 5 years I was pulling engines and everything.  Nothing is very difficult, just read and thoroughly understand everything before you start.  Most mechanics I have suffered through, guess, and mess up everything.
BJM
  • Guest
« Reply #2 on: June 17, 2019, 04:06:23 PM »
So, one method I use when replacing parts is to see how the old part is affixed/attached or set up.  BEFORE removing the old part observe, take photos of the wiring, fasteners, etc so that the new part goes in the same way.   You need a new mechanic, sorry.
I'm with Scot, grounds are pretty easy to make.
Interior lights not going out also is usually a ground issue.  Wiring diagram is needed. At the very least, pull the fuse.
Sounds like you purchased one of those "time capsule" 1976 Eldorados that was never driven because collectors thought it was truly the last convertible.
Offline Bentley
  • Name: WBentley
« Reply #3 on: June 17, 2019, 04:25:33 PM »
Clinton,
You might try going to some local car shows, and asking some of the owners where they get their cars worked on. Once you get a referral to a mechanic, get the shop manual and bring it with you.
Wes Bentley
CLC # 30183
  • Name: Eric DeVirgilis
« Reply #4 on: June 17, 2019, 06:02:39 PM »
Is the car equipped with Illuminated Entry System? (Identified by small clear plastic light diffusers built into the exterior door handles just above the door lock cylinders)
Offline Cape Cod Fleetwood
  • CLC #31411
  • Name: Laurie Kraynick
« Reply #5 on: June 17, 2019, 06:57:10 PM »
Clinton,
^ *BOOM ^
A mechanics/shops best advertising are the old cars at the shows.
\m/
Laurie
The Past -
1996 Deville Concours
1981 Coupe De Ville (8-6-4)
1976 Sedan De Ville
1975 Sedan De Ville
Offline cadillacmike68
  • Still crusin'
  • CLC Number: 15823
  • Name: M Santos
« Reply #6 on: June 17, 2019, 07:16:29 PM »
Courtesy lights not going out is usually a door pin switch or the headlight dimmer resistor. Illuminated Entry might make this a bit more complex.
We don't all have the space, tools and $$$ to buy them that Scot has.
"Cadillac" Mike
« Reply #7 on: June 17, 2019, 08:00:21 PM »
...or a fault in the Illuminated Entry System...
« Reply #8 on: June 18, 2019, 12:48:56 AM »
Eric is probably right, I had to disable the illuminated entry system on a 1976 FWB to keep the interior lights from staying on and draining the battery.  Usually the door switches fail to turn on interior lights, not keep them on if they break.
Offline V63
  • Name: W Link
« Reply #9 on: June 18, 2019, 03:14:00 AM »
A few quick checks. ✅
✅The interior lights can manually initiate by ‘turning’ the head light switch knob fully clockwise until you feel a detent. Might verify that did not happen by turning it counter clockwise off the detention.
✅The twilight sentinel eye (for headlights only) is in the drivers speaker grill, if a dash mat (or other obstruction) is upon the dash or sensor...it will effectively sense night 🌘 time conditions.
« Last Edit: June 20, 2019, 03:38:52 PM by V63 »
« Reply #10 on: June 18, 2019, 03:34:38 PM »
The Twilight Sentinel is completely independent from the courtesy lighting circuit in 1976.
It wasn't until the late '80s when outside lighting conditions determined whether interior illumination was called for.
« Last Edit: June 18, 2019, 06:34:27 PM by Eric DeVirgilis CLC# 8621 »
STS05lg
  • Guest
« Reply #11 on: June 18, 2019, 06:28:41 PM »
Clinton, if your car is equipped with illuminated entry as noted above with a light over the door handle push button, then the reason that your lights will not go out is a faulty illuminated entry module. These modules are not available NOS or on the after market. It is located behind the kick plate next to the emergency brake. The only solution is to disconnect it. Then the interior lights will work normally (interior lights on when you open a door and interior lights off when the door is closed, there will be no time delay once it is disconnected). The failure of this module will run down your battery very quickly. If you do not have illuminated entry is is most likely a door switch failure as noted by others. Hope this helps. Lynn
Offline Glen
  • CLC Number: 727
  • Name: Glen Houlton
« Reply #12 on: June 19, 2019, 01:58:59 AM »
Is this module encapsulated?  Is it possible to repair it?
Glen Houlton CLC #727
CLCMRC benefactor #104
« Reply #13 on: June 19, 2019, 08:46:09 AM »
The relay was probably not designed to be serviceable...but who knows what some wiz might be able to accomplish...
Offline 76eldo
  • CLC Number: 22443
  • Name: Brian Rachlin
« Reply #14 on: June 19, 2019, 09:22:39 AM »
The OP can see a wealth of information if he comes back to check on the posting...
CLC # 22443
Offline bcroe
« Reply #15 on: June 19, 2019, 09:33:08 AM »
Electrical work seems to escape a lot of people, including some
mechanics.  Is there a ELECTRICAL CERTIFIED certificate for
mechanics?  It is not heavy work, but getting access to the wiring
can be a problem in a vehicle.
The first step is getting the manuals covering the vehicle, and do
be prepared to find errors.  Tracing will involve using your meters
to lead you to a fault, do not assume a fault will be visible to the
eye.  Then there is a matter of making wiring repairs suitable for
the environment they must survive.  Many modules can be sent
out for repair, simple ones fix yourself.  good luck,
Bruce Roe
« Reply #16 on: June 19, 2019, 10:38:19 AM »
This illuminated entry feature is easily disabled and then it functions as a regular car with lights turning on when you open the door.  Yes of course it can be fixed by the juice will not be worth the squeeze.
« Reply #17 on: June 19, 2019, 10:39:52 AM »
My memory may be sketchy but I vaguely remember a picture of of the fuse block with an arrow pointing to a wire that ran into the front of fuse block being labeled "Illuminated Entry Bypass".
Bill Young
  • Guest
« Reply #18 on: June 19, 2019, 12:17:22 PM »
I had the same problem with the interior lights on my Eldorado Convertible. The problem is harder to trace because your car applies ground when you open the door. rather than power as in most cars. Here is what you do. Put the fuse in the fuse block and all the lights will be on. Then remove the dash panel below the steering wheel. Then look in the left corner for several white plastic connectors , these control each quadrant of interior lights , left rear , left door etc. My problem it turned out was a short behind the right front kick pad. The same fuse powers the seat back releases also. I hope this helps.
