Hello: The speedometer stopped working on my 1976 Eldorado. I found the following thread, which has many of the forum veterans weighing in, and will follow it for further troubleshooting. So far we have simply verified that the cable from the transducer to the speedometer turns freely, with the speedometer responding accordingly.
http://forums.cadillaclasalleclub.org/index.php?topic=150480.0I do have a few questions though, and did not see the information in the factory service manual, but may be looking in the wrong area.
1. Is this a reservoir of some sort associated with the transmission speedometer gear? If so, does it require fluid check, or? I was trying to pull the cover, but decided to post first after the following……
2. After removing both speedometer cables from the cruise control transducer, I happen to look down and found the copper washer shown in the photo directly underneath the transducer. I am not sure if it happened upon removal of the cables, or came from somewhere else. It will fit the cable connection which goes to the speedometer, but not positive where it belongs. Does it ring a bell with anyone?
I figured the next step was to disconnect the cable from the transducer to the transmission, and attempt to drive the transducer as 76 cadillac bob did.
Your comments appreciated. Hopefully I've attached my photos correctly. Thanks, Toukow
