1955 Cadillac Headlight Dimmer Switch
Started by Bill Young, July 04, 2019, 10:09:58 AM
Bill Young
Who sells the correct 1955 Cadillac replacement floor dimmer switch and also almost more importently the floor switch that sits to the right of it that is the temporary override to high beam for the Autronic Eye ? Mine is missing . Thank You
MickeyCaddy
I need one of these too for my ‘55. I’ve done some searching, but haven’t had any luck. Would love to find a new replacement part; not NOS, which would likely be super-expensive, if it’s even available.
Jay Friedman
According to my 1935-55 Master Parts List, the foot-operated dimmer switch is the same from 1934 to 1955, so should not be difficult to find 2nd hand.  It's part number 199 7008.  Try Dennis Akerman or John Gately, who are in the CLC directory in NH and MA, respectively.
Alternatively, here's a NOS one on ebay:
https://www.ebay.com/itm/1938-1958-GM-NOS-DIMMER-SWITCH-CADILLAC-BUICK-ROADMASTER-PONTIAC-STARCHIEF-OLDSM/372678146729?fits=Year%3A1955%7CMake%3ACadillac&hash=item56c5593aa9:g:FQsAAOSwW1Bc6uxx
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
I have a standard dimmer switch 1946 to 1958 for $ 30.00. The dimmer switch for cars with Autronic Eye is specific of course and diferent. There is no override switch next to the standard switch, this function is assumed by the specific switch.
Caddy Wizard
If you have the old switch, it is a simple matter to take them apart, clean the contacts and lube them with bulb grease, lube the moving parts, and reassemble.  Same thing for mechanical brake light switches.
Art Gardner
1958 Eldo Seville (2/3 done)
Jay Friedman
Decatur, Georgia
chrisntam
1970 Deville Convertible
Dallas, Texas
J. Gomez
Quote from: chrisntam on July 11, 2019, 01:07:52 PM
I hope not, not for $325 for a dimmer switch?
That one is for the Autronic-Eye control (on or off) and if you want 100% authenticity $$$ is not an issue, but if you want functionality a simple modification of a foot switch would do it.  ;)
J. Gomez
CLC #23082
My '56 Biarritz  and '57 Brougham have the Autronic Eye. I don't have this funny switch; in the accessories, there is an auxiliary foot switch, group 53.0290, # 1997022, which is a tad more expensive than the standard foot switch. I'm sure that the switch in eBay is a wrong one.
J. Gomez
#9
Quote from: Roger Zimmermann on July 11, 2019, 01:30:23 PM
Roger,
The 1955 has two one is the regular beam-selector foot switch for the headlights and the other override is for the Autroni-Eye control. For 1956 and after they went to a single switch and added the functionality under one.   ;)
The “red” wire on the single switch is for the Autronic-Eye control to either turn it “off” momentarily for passing by just slightly pressing when the high beams are on or by turning the Autronic-Eye function off by pressing it down.
The single foot switch on the 1955 with the “red” wire functions the same.
HTH
Sorry forgot to include the wiring for 1955-1956
J. Gomez
CLC #23082
MickeyCaddy
I've been researching this for a couple of years. That's the exact switch for a '55; it has the tell-tale single red wire. But holy cow...$325.00! This is the first time I've seen one of these for sale, and I expected it to be expensive; but not THAT much.
Thanks for the explanation of the change for '56 and up. Now I see why these are so hard to find. The online item in the link above is listed as for a '57, but that's probably incorrect. FYI, the smaller dimmer switch in my '55 is physically damaged, bent.
Until now, I've only been able to find a few online pictures; here are the two switches connected together with the red wire visible; a '55 floor gasket; and '55 interior showing the Autronic Eye and floor switches.
Quote from: J. Gomez on July 11, 2019, 01:51:19 PM
Jose: thanks for the explanation!
J. Gomez
Quote from: MickeyCaddy on July 11, 2019, 09:23:43 PM
FYI
The one on your first picture (dual foot switch) was used on the ’52-early ’54 with Autronic-Eye part 5943291, the late ’54 and ’55 the auxiliary switch was independent part 5945230. The dual foot switch was also used on other GM models with the same Autronic-Eye feature.
There is a chance you could rig one up that may look close to the original just for the auxiliary one, if you are not looking for 100% authenticity.  ;) This one is just an “on-off” type which connects to the chassis ground at the base and extends it to the wire.
Good luck..!
J. Gomez
CLC #23082
From the look of it, I didn't think it would be too hard to "modify" a normal dimmer switch to do the same task.
Especially when the cost of the replacement was so high.
MickeyCaddy
Thanks guys â€" since it's a simple momentary switch, it sounds like I can work this out without using the correct original part.
Jose, thanks fo the explanation of the differences between the '52 â€" early '54 switch and the late '54 â€" '55 unit. That explains what I noticed in the pictures I've seen and posted: the '52 â€" early '54 switch, which I now understand was siamesed with the main dimmer switch, appears to have two rivets permanently connecting it to the flange surrounding the main switch. The 1957 switch pictured on eBay is differently shaped, and has three grommets around its flange, as if it's designed to be screwed onto the main switch.
I'll have to look further into what's installed on my '55; almost everything on this car has turned out to be factory original.
Bill Young
Thank you guys , the floor grommet switch setup is identical to the turquoise blue 1955 car pictured above.
