2009 CTS B0248 Code versus 1957 Caddy Heat controller
Started by Bill Balkie 24172, August 01, 2019, 05:57:08 AM
Bill Balkie 24172
Hello To All ,
   Just thought i would share this with you ( check out the Video)  , The Air Conditioner on my 2009 Cadillac CTS works fine . However the Air will no longer blow out of the center two vents on the Dash . instead the air blows cold out of the bottom vent onto the floor. Also this effects the windshiels defroster . Returned it to the Cadillac dealer in town and they diagnosed the problem as B048 code . The actuator was stuck . That  cost me 178.58 for them to tell me this was the problem . To fix this problem the entire dash has to be removed along with the steering wheel , center console and both front seats .The cost  2,299.99  Could not stop thinking of my 1957 Cadillac in the Gararge . It has a slide control with a wire and coble to control the same  thing .  I could fix  the same problem in my 57  for about 29.00 .
https://api.mykaarma.com/inspection/v1/walkaround.html?fileType=image_and_video&inspection_uuid=5d3efdc23077170001007df6
  Just had to Vent ,
            Bill
Bill Balkie
1970 Coupe DeVille
2009 CTS
