1960 Cadillac Miller Meteor Commercial Chassis Hearse
Started by LPIENS, August 09, 2019, 05:23:47 AM
LPIENS
Hello, I have a 1960 Hearse on a cadillac commercial chassis ( series 75)
I imported it from Venezuela back to Europe.
I have some trouble finding the right wheels and tires.
I found some things about the measurements online for the wheels. but I can not locate any original wheels in Europe.
So I found a set on Cokertire.com and want to know if they are the same.
Can someone help me out ?
about the original wheels
I have found online:
wheel size 15 X 6
Bolt circle 5 bolts 5 inches
wheel number X-40129 .
On coker tire I found these:
https://www.cokertire.com/wheels/original-equipment/o-e-style-chevy-wheel-oepr156lg334.html
Backspacing is 3,75 inch .
Would that fit and not block on turning the front wheels?
And For tires I found these:
https://www.cokertire.com/h78-15-coker-classic-3-whitewall-tire-62861.html
or these
https://www.12banden.be/cgi-bin/rshop.pl?dsco=433&typ=R-215148&partner=1&ID=psm_rdd_benl_vergelijk&Country=DBENL
Is This correct?
Thank you for helping out!
One of the reasons for using original Cadillac rims for your model year is that they have a deeper outer lip, which is there to retain the full disc wheel trims.
Use the narrower lip rims, and it is hard to keep the trims from falling off.   I found that problem with my '60 CDV.
Plus, from memory, the Commercial Chassis Cadillacs used heavier duty rims, because of the extra weight of the vehicles.
