"Sidewalk Bolts" Used For Floor-Boards and Fender Mounting 1937 LaSalle
Started by carlhungness, August 21, 2019, 11:50:34 PM
carlhungness
       The term 'sidewalk bolt' is a new one to me and I think I discovered it last year in my quest to obtain the proper round head slotted 1/4-20 screws used to hold down the transmission cover plate.
         The front end I obtained is barely together and it appears as though these same bolts are used through the fenders into captured nuts on the radiator shell. Am I correct?
        Someone mentioned the sidewalk bolt term and I wound up buying a package albeit with a phillips/straight slot head.
Bobby B
Also referred to as "Hurricane Shutter" Bolts. Not 100% original looking, but readily available in many lengths and a 100 pack of stainless is cheaper than a couple of original looking ones. Who's looking under your Carpet and Firewall?
                                   Bobby
1968 Mustang Convertible
1973 Mustang Convertible
1969 Jaguar E-Type Roadster
1971 Datsun 240Z
1979 H-D FLH
las39
Thank you for this info. Can't find them in MPL. Any one know what part #?
1939 LaSalle 5027
1941 Chrysler Royal Coupe
1934 Oldsmobile F34
1976 Moto Guzzi Convert
Bobby B
Quote from: las39 on August 22, 2019, 05:02:03 PM
Here you go.......
                          Bobby
https://www.windstormproducts.com/1-4-sidewalk-bolts/
1971 Datsun 240Z
1979 H-D FLH
las39
I think you misread my question. ;) I can't find them in MPL (Cadillac Master Part List)
1939 LaSalle 5027
1934 Oldsmobile F34
carlhungness
Neither can I. I am wondering if they are the same bolt that holds the front of the fender to the grille shell. The front end I bought has a couple installed and it looks like the rest of them had the large head. I'm not worried about the look but if possible I'd like to find originals for the fenders, I like the single slot.
Brad Ipsen CLC #737
Have not found these in the MPL to date.  For sure they are not in Group 25 where all the standard bolts, screws etc. are.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
1940 Cadillac 60S Limo
