31 CADDY V-8
Started by terryufs, August 30, 2019, 08:25:03 AM
terryufs
  WHAT IS THE PROCESS TO START THIS VEHICLE. I WAS TOLD THERE IS SOME SWITHES ON THE STEERING WHEEL .
Chris Cummings
Hi,
Is your car complete and in good working condition?  Are all the controls in working order?  If so, the attached excerpt from the 1931 V-8 owner's manual gives a complete starting routine.  The throttle control is a lever above the horn button on the steering wheel hub.  If it's missing or not working, just be sure to keep the accelerator pedal partially depressed during starting and warm-up.  You can access the entire owners manual at the GM Heritage Center website if you don't have a copy.  Good luck with your car.  Can you tell us about it?
Best regards,
Chris Cummings
terryufs
Thanks for the help, Chris. I just purchased the car from an estate and I haven't tried starting it yet.
Where is the best place for parts for these cars. I'm going to need plugs and oil filters.
Bobby B
Quote from: terryufs on August 30, 2019, 12:38:24 PM
We Need pictures!  ;D ;D ;D
All the info you want is right here. Just ask.....
                                                    Bobby
1968 Mustang Convertible
1973 Mustang Convertible
1969 Jaguar E-Type Roadster
1971 Datsun 240Z
1979 H-D FLH
terryufs
where can I get a carb rebuild kit
Chris Cummings
There are several sources:
Classic and Exotic Services
https://www.classicandexotic.com/store/p-662-cadillac-johnson-carburetor-repair-kit-1927-1931-v8.aspx
Pete Sanders
http://fm22.triple8.net/fmi/iwp/cgi?-db=PartsDatabase04-12-07&-loadframes
You can also contact Classic Carburetors in Phoenix or Daytona Parts Company in New Smyrna Beach, Florida.
Best regards,
Chris Cummings
terryufs
  Chris, where can I get a heavier amp battery for that car.
Bob Hoffmann CLC#96
I'll make several suggestions. You are moving a little too fast on this car for a newbie.  When was the last time it was run?? One other important thing is the car is POSITVE ground.
Bob
Chris Cummings
Most battery shops should be able to sell you a heavy duty six-volt battery that fits your battery box.  The shop manual calls for 120 amp-hours.
terryufs
  Yes the car has positive ground and we got the car running last week.
