1975 Eldo Convt Headlight and Wiper Switch testing
Started by stowe75, September 02, 2019, 11:53:31 AM
stowe75
Hello I am in the process of restoring my 75 eldo . The main dash and pad have been restored. I would like to bench test the headlight switch and wiper switch prior to re installing. Was hoping to find a process to test the switches.  Thanks
You could just plug it into the car harness and see if it works,
before mounting it.  My test sets are mad using junk yard wiring
harnesses, with a power source and indicators added.
Bruce Roe
