1938 60S Front Seat Removal
Started by 1940_5219, September 04, 2019, 10:33:49 PM
1940_5219
Good evening,
My father in-law has a 1938 60s that he is trying to remove the front seat, but he cannot figure out how to access the bolts that mount it to the body. Is the front cushion removable?
John O'Toole
G Pennington
If it's like my '41, you just lift the front of the bottom cushion and it comes right out.  You can then access the bolts.
Gary Pennington
   1953 6267X Convertible
   1941 6267D Convertible (2 door)
Brad Ipsen CLC #737
Seat construction totally changed between 40 and 41. No removable cushion in a 40-60S.  Can't confirm it for sure but I think 38-60S is the same as 40.  Remove the skirt that is on the side.  There are 6 or 7 screws holding it on.  You then have access to the bolts that hold the seat adjustment mechanism to the floor.  Picture shows the skirt.  If you 38 looks like this I think we can assume the construction is the same as 40.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
1940 Cadillac 60S Limo
