The 88 is a standard display test code. That will come up every time. They used "88" so you would know that all of the segments in the LCD screen for the digits are working. 38 refers to an open MAT sensor circuit. That's Mainfold Air Temp as I recall. I'd look at the connector abd maybe unplug it and plug it back in. Could be an oxidized or loose connection. If the sensor was bad I think it would stay in a trouble condition.
Bruce Roe is the Guru on these things. If you don't see him respond to this maybe send him a message.
Hopefully you have a shop manual. It should tell you which sensor is which and then you can look at the connector on it.
Here is a full list I found on another Cadillac forum. Gotta love cut and paste commands:
Code
Circuit Affected
00 (E00)
No PCM systems faults
12 (E12)
No TACH Signal
13 (E13)
O2 Sensor Not Ready
14 (E14)
Shorted Coolant Sensor
15 (E15)
Open Coolant Sensor
16 (E16)
Generator Voltage Out Of Range
17 (E17)
Crank Signal Circuit High
18 (E18)
Open Crank Signal Circuit
19 (E19)
Fuel Pump Circuit High
20 (E20)
Open Fuel Pump Circuit
21 (E21)
Shorted Throttle Position Sensor Circuit (DFI)
Wide Open Throttle (WOT) Position Sensor Circuit (all others)
22 (E22)
Open Throttle Position Sensor Circuit
23 (E23)
EST/Bypass Circuit Shorted or Open (DFI)
Mixture Control (M/C) Solenoid Open (Carbureted)
MAT Sensor Circuit - Low Temp (TBI/all others)
24 (E24)
Vehicle Speed Sensor (VSS) Failure
25 (E25)
Modulated Displacement Failure (v8-6-4)
EST/Bypass Circuit Shorted or Open (HT4100)
MAT Sensor Circuit - High Temp (TBI/all others)
26 (E26)
Shorted Throttle Switch Circuit
27 (E27)
Open Throttle Switch Circuit
28 (E28)
Open Fourth Gear Circuit
29 (E29)
Shorted Fourth Gear Circuit
30 (E30)
Idle Speed Control Circuit
31 (E31)
Shorted MAP Sensor Circuit (DFI)
Canister Purge Problem (all others)
32 (E32)
Open MAP Sensor Circuit (DFI/TBI)
BARO Sensor Circuit Problem (Carbureted)
33 (E33)
MAP/BARO Sensor Correlation (DFI)
Shorted MAP Sensor Circuit (all others)
34 (E34)
Vacuum Sensor/MAP Hose (DFI)
Open MAP Sensor Circuit (all others)
35 (E35)
Shorted BARO Sensor Circuit (DFI)
Idle Speed Control Circuit Shorted (all others)
36 (E36)
Open BARO Sensor Circuit
37 (E37)
Shorted MAT Sensor Circuit
38 (E38)
Open MAT Sensor Circuit
39 (E39)
TCC Engagement Problem
41 (E41)
Electronic Spark Timing (EST) Problem
42 (E42)
Electronic Spark Timing (EST) Circuit Open
43 (E43)
Electronic Spark Control (ESC) Problem
44 (E44)
O2 Sensor Lean
45 (E45)
O2 Sensor Rich
51 (E51)
PROM Insertion Fault
52 (E52)
ECM Memory Reset Indicator
53 (E53)
Distributor Signal Interrupt (HT4100)
ECM Unit Fault (V6 Models)
EGR Valve Vacuum Problem (all others)
54 (E54)
Mixture Control (M/C) Solenoid Shorted
55 (E55)
ECM/Oxygen Sensor Fault
60 (E60)
Drive (ADL) Switch Circuit
61 (E61)
Set and Resume Switch Circuit
62 (E62)
Car Speed Exceeds Maximum Limit
63 (E63)
Car and Set Speed Tolerance Exceeded
64 (E64)
Car Acceleration Exceeds Maximum Limit
65 (E65)
Coolant Temperature Exceeds Maximum Limit
66 (E66)
Engine RPM Exceeds Maximum Limit
67 (E67)
Shorted Set Or Resume Circuit
70
System Ready - Switch Tests
71
Brake Light Switch
72
ISC Throttle Switch
73
Drive (ADL) Switch
74
Back-Up Lamp Switch
75
Cruise On/Off Circuit
76
Set/Coast Circuit
77
Resume/Acceleration Circuit
78
Instant/Average MPG Button
79
Reset MPG Button
80
A/C Clutch Circuit
88
Display Check (-.1.8.
90
System Ready To Display Engine Data
95
System Ready for Acuator Cycling
96
Actuator Cycling
97
MD Cylinder Solenoid Cycling
00
All Diagnostic Complete
