Thanks for the replies, the boneyard rotors, if I spend the time to wrench them off of the verhicles that they are on, would be off of two different 1969 deville convertibles. I measured them in two different spots, they are 1.236 thick, so if they were to get turned perhaps would end up being under the 1.230 minimum. If I go the new rotor route, do they include the inner and outer bearing cups? (the picture on the Oreilly site looks like they do), and can and/or should I use my existing inner and outer wheel bearings?
New Rotors come fitted with bearing cups, but you have to purchase the cones separately.If your own bearings are known to be good, then simply remove them, with the cups, and put them into the new rotors.One thing to be very careful of is not to purchase new rotors that are made in China. I would prefer to use old US made ones, machined, than new Chinese, and that includes the bearings as well.Bruce.
Change the bearings, they usually come with the rotors.
G'day Mike,Thanks for bringing that up. It was myself that did the conversion, and wrote it up on the Modified Chapter.http://www.modifiedcadillac.org/articles/onepiecediscswap/onepiecediscswap.htmlBruce. PS. Not sure why it comes up in blue, which makes it very hard to read. See if the attachment makes it easier to read.
