Author Topic: Power antenna relay on a 1975 Eldorado convertible  (Read 433 times)
Offline KWirth
  • Name: K Wirth
« on: October 20, 2019, 04:16:46 PM »
I just installed a completely rebuilt and functioning power antenna.  The antenna works perfectly when tested with the battery but when it’s connected to the power harness nothing happens with the ignition switch on, radio on and power antenna switch in the up position.  After some investigation I believe the power antenna relay is bad.  Does anyone know where I can get a replacement relay?  I haven’t found any in my online searches.  Thanks in advance for your help.
