All Cads
Author Topic: Voltage regulator trouble?  (Read 505 times)
Offline 2danreed
  • Name: Dan Reed
« on: October 25, 2019, 05:22:32 PM »
I just replaced the alternator and voltage regulator on my "64 Cadillac. Everything seems to be charging correctly (12 volts at bat. with car off, 13-14 volts when the car is running) Odd problem is that the volt. reg. is causing the GEN light to come on while driving at certain rpms, it blinks on as I slow to a stop. Then blinks on again as I take off from a stop, but stays off while cruising speed. Then when I park and turn the car off the GEN light comes on! I can only get it to go off if I disconnect the four wire plug on the voltage regulator. What's the deal?
Dan Reed
Offline Bobby B
  • Mendham, New Jersey
  • Name: Bob Bender
Re: Voltage regulator trouble?
« Reply #1 on: October 25, 2019, 07:26:42 PM »
Maybe the VR needs to be adjusted? "New" Alternator could have a bad diode or dead spot once it heats up. All this stuff is from China now and the quality of the rectifiers are terrible. They will trash a computer in a modern car.
        Bobby
1968 Mustang Convertible
1973 Mustang Convertible
1969 Jaguar E-Type Roadster
1971 Datsun 240Z
1979 H-D FLH
Offline z3skybolt
  • CLC Number: 30482
  • Name: B. Ritchie
« Reply #2 on: October 25, 2019, 10:54:26 PM »
might want to check with Brillman. I bought a high quality made in the USA regulator and other parts from them. Mine was $96.00.  Not cheap but good quality. Working perfectly after 500 miles.
https://brillman.com/?gclid=EAIaIQobChMI7PKWyfW45QIVah6tBh1qqwETEAAYASAAEgL6BPD_BwE
Bob R.
Offline 2danreed
  • Name: Dan Reed
« Reply #3 on: October 28, 2019, 03:18:40 PM »
Thanks guys.  I decided to go with an upgrade to an internally regulated 3-wire alternator. That did the trick. Its charging correctly and the GEN light comes on only momentarily at startup and goes out when running and when the car is turned off. That external regulator must have been the culprit.
Dan Reed
