G'day John,I personally would be using just Dexron III, and then jacking the car up and turning the steering wheel from lock to lock, eventually bleeding the system.Jacking the car up, takes the pressure off the steering components, not to mention your own muscles.Bruce.
BRUCE! Why wouldn't you prefer to use the GM power steering fluid that is factory recommended for these systems instead of the ATF fluid? EAM
