'49 Series 62 Trunk hinge removal
Started by tower154, November 27, 2019, 04:51:13 PM
tower154
Can anybody tell me how to remove the trunk hinges from my sedanette.  There are two pins that hold the hinge mechanism in the body channel, but the pins seem to be frozen solid.  Do I need to release the spring tension somehow to reduce the force on the pins?  The pins are tapered on one end, but it is difficult to see if they are peened over to keep them from falling out.
1949 Series 61 Club Coupe
1949 Series 62 Club Coupe
Jay Friedman
Try Joe Cutler at 49caddymanemail addresses not permitted
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
tower154
Finally got them out.  The hinge pins are splined on the head end.  Penetrating oil and a few taps from the tapered end and they came out.  :)
One body is now completely torn down except for the door hinges...the cover plate screws/bots are a bear to get out :(
