1956 Cadillac paint code assurance?
Started by carguyblack, December 10, 2019, 07:53:55 AM
carguyblack
I have painted four 1956 Cadillac with all but one being black so color matching wasn't an issue. The other one was in Canary Yellow, which also didn't matter if it was exact. Now, however, I am painting a convertible for a friend and I want to be correct with it. The code color is Sonic Blue. My question is: Going to a paint shop, would they be able to still bring up the VIN paint code number and mix it properly? Where do you go when trying to be as exact as possible?
We don't have a color chart to match nor any part on the car that would be a good candidate to match a color spray sample comparison.
I don't want this guy going to a show someday and park next to another Sonic Blue car and have his be a shade or two off!
Thanks for the guidance before I pull the trigger. (pun intended!)
Chuck
Chuck Dykstra
1956 Sedan DeVille
1956 Coupe DeVille (2 sold)
1957 Oldsmobile 98 (sold)
1989 Bonneville SSE
57eldoking
The VIN does not contain any information on paint.
Here are the Cadillac, PPG and Dupont codes for Sonic Blue
1956 Cadillac: 20
Ditzler PPG: 11475
DuPont: 2295, 246-59593
1957 Eldorado Biarritz #906
1957 Eldorado Biarritz #1020 http://bit.ly/1kTvFlM
1957 Eldorado Seville  #1777 http://bit.ly/1T3Uo1c
1995 Fleetwood Brougham  http://bit.ly/20YwJV4
2010 SRX Performance
1946 Chevy 1/2 ton pickup
1957 Buick Caballero Estate Wagon (x2)
1960 Chevy Apache 10 Stepside
1991 Jeep Grand Wagoneer (x2)
1992 Pontiac Trans Sport GT
goob
Contact tcpglobal.com or autocolorlibrary.com (more or less the same place)...they will get you whatever you need...they recently made some Monica Blue for our 41 convertible coupe...its perfect!
J. Gomez
Chuck,
Not sure if you have the old DuPont Color library link (maybe you forgot  ;)) here is the link -> http://historicalcolorlibrary.axaltacs.com/hcl/
They have the old formula so not sure if your local supplier would be able to mix it with the older format.
I have the two tone on mine Sonic Blue and Cobalt Blue, I gave the shop the paint chips for both from DuPont site and were able to get them mix, although not sure if it is 100% but it is a real close match.
Good luck..!
J. Gomez
CLC #23082
cadman56
When I completed the restoration of my Sonic Blue 56 convertible PPG came the closest to maatching the original color.  None of the other brands in my area were even close, even with the original mixing codes.  they explained the original mixing tints were no longer availabe.
I  used a single stage urethane on my convertible.  A pretty onve when finished.
1967 Cadillac Eldorado (sold)
Larry Blanchard CLC #5820
carguyblack
Wow! Thanks for all the great help with this. I'm deciding to at least seek out the PPG mix as apparently it's as close to original as you can get 60 years down the road. I'm excited to get it mixed and see for myself.
Is there a drawback in doing it in base/clear? That's what I'm used to but if the majority tell me differently, I'll go single stage. My first yellow 1956 was in PPG single stage and it looked great, too. I'm open.
Again, you guys are wonderful!
Chuck
Chuck Dykstra
1956 Sedan DeVille
1989 Bonneville SSE
