'65 CDV rear seat back removal with center armrest
Started by bctexas, December 28, 2019, 04:22:46 PM
bctexas
Hi all - I am in the process of replacing the package shelf on my '65 CDV, and searched this site and the '65 body manual for info on removing the rear seat.  I discovered that neither source accounts for a rear seat back with a center armrest.  The instructions say to pull the bottom of the seat back away from the body after bending the sheet metal tabs back, and lift to clear the upper hooks.  Well, mine would not budge.  I found that there are two Phillips head screws behind the trim "curtain" that runs from the back of the arm rest to the top of the seat opening.  I was able to reach these screws by pushing the curtain to the side slightly, and the seat lifted right out as described.
Hope this info is of use to someone!
Happy Motoring!
1965 CDV
1970 SDV
