1958: Front bumper removal
Started by wbdeford, December 28, 2019, 06:26:23 PM
wbdeford
The shop manual says only 6 bolts--3 per side, need to be removed to remove the bumper.  I couldn't see any way to do it without removing at least 4 (I removed 5).  I thought maybe there was a misprint, so I checked my 57 and 59 manuals....57 is the same, and 59 says only 2 per side!
Anyone know what 3 bolts per side will get the bumper off, or is the manual wrong?
These are the 5 I removed.
1958 Sedan de Ville
Past:
1956 Fleetwood 75 Sedan
1957 Fleetwood 60 Special
1960 Coupe de Ville
1966 De Ville Convertible
1970 De Ville Convertible
1971 Eldorado Convertible
1979 Sedan de Ville
1980 Seville
signart
Not that familiar with this model, but of the perhaps numbering in the hundreds of other front & rear bumpers by now that I have removed, normally they are unbolted from the frame with the brackets still attached to the bumper. The brackets can then be separated from the bumper. Usually 3 bolts each side.
I just saw this, but I think it's strange that someone has not given a response before now. :-[
Art D. Woody
If you want the whole assy off, take off at the frame support brackets - back behind what you removed.   Otherwise, it's a bunch of pieces bolted together.   That way you don't have an re-alignment puzzle going back in.
I paid a shop to change my front center section, as it's a big job for one guy and after I did the back myself and had molten metal flying at my eyes and down my arm, torching the frozen nuts off.
Daddio
Be sure to take pictures before removing the brackets / bumpers. I was glad I did on my '59, I couldn't believe how many ways those pieces could go back together.
SOLD - 1959 Eldorado Biarritz
