Leaf Spring Removel
Started by DANDOR, December 30, 2019, 02:35:38 AM
DANDOR
HI everyone need help removing leaf springs on 1939 Cadillac Lasalle rearend is out of car already unbolted shackles and took nuts off of front hangers my question is how do you get the hanger bolts out they appear to be built in to the shackle ant help would be appreciated thank you
DANDOR
I have a 1939 Cadillac Lasalle that I am trying to take the leaf springs out of I already removed the rear end and rear shackles plus the front hanger nut but how do you get the bolt out of the shackle it appears to be welded in do I have to cut it any help will be appreciated thank you
Fred Pennington 25635
The front spring bolt has a very large circular head and is somewhat pressed in to the front spring mount.
It visible from the inside of the frame.
The bolt can be removed by driving it out from the nut side. You can run the nut on and hit with a hammer or use a drift pin or punch. if the bolt is worn or damaged you can get a replacement from ZIP Corvette. They are the same as a C1 Corvette.
Fred Pennington, CLC 25635
1940, LaSalle 5019
1940 LaSalle 5019 parts car
1968 Ford Bronco
1973 Mustang Convertible
2012 Shelby GT500
DANDOR
Thank you very much I will give it a shot tomorrow
ebuliavac
I am looking toward doing the same thing with my 1940 6227C.  If you are referring to the eye bolts in the front of the leaf spring, there is a cover with spanner wrench holes on the inside of the frame.  If you have this, perhaps turning it with a spanner wrench will ease the process.  Also, you can heat it with a torch.  Let us know how it works out.  Best, Ed
1940 6227C
1996 Fleetwood Brougham
Classic
As Fred Pennington said, I found the rear spring front eye bolt at www.Zip-Corvette.com.  It's their part number SU-382.  Thanks Fred.
Gene
Gene Menne
CLC #474
#6
ebuliavac, There is no cap. You are looking at the head of the the shackle bolt.
The originals have two holes for a spanner wrench, The replacements don't have the holes.
The edge of the large head has some serrations to keep it from pivoting with the spring.
1940, LaSalle 5019
1968 Ford Bronco
2012 Shelby GT500
DANDOR
Thanks for the help everyone got both springs out today using a pipe and hammer hitting the side where the nut goes and driving it though the frame very easy to do
Hilarius
Wait till you try to put the springs back on your '39. No fun! The manual tells you how.
Hilarius
Hilmar Schneider #26898
1930-162, "353", 4D-SDN-7P
1940-7567, 2D-CCP-2/4P
1948-7519X, 4D-SDN-5P
1952-6019X, 4D-SDN-5P
1973 Mercedes 107R, 2D-CCP-2P
2015 Cadillac SRX, 4D-SDN-5P
DANDOR
cant wait sure it will be fun I don't have a manual to go by either
