472/500 Oil Pressure Switch Removal
Started by hornetball, January 01, 2020, 11:24:21 PM
hornetball
Howdy.  Need to replace my oil pressure switch but my special socket won't fit over it.  It is too close to the block.
What have all of you used to unscrew these?  Maybe I just need a better socket (thinner wall)?
Glen
I could not find a socket to fit, so I made my own using some thin wall tubing.  Now I use this tool https://www.ebay.com/p/1123777742
Glen Houlton CLC #727
CLCMRC benefactor #104
hornetball
Jeff Rosansky CLC #28373
Off the top of my head in think I got mine at Napa. Worked just fine.
Jeff Rosansky
CLC #28373
1970 Coupe DeVille (Big Red)
1955 Series 62 (Baby Blue)
Dad's new 1979 Coupe DeVille
And this must be a RWD car so there isn't room to get back there with a flat wrench?
