Rocker molding clips
Started by Jan Egil, January 06, 2020, 12:20:50 PM
Jan Egil
Does anyone have pictures / drawings on rocker molding clips for 49 Cadillac?
Brad Ipsen CLC #737
I have just restored a 49 CDV.  Assuming all 49's are the same as the CDV (I do not know this for sure) there are no clips.  There are sheet metal straps at the top that catch the top edge of the rocker molding.  The bottom is then held by screws up into the body.  For some reason the strap on the front fender portion is stainless and the body is steel.  The steel ones rust away.  The straps are a little more than 1 inch wide.  The ones on the body are screwed in and the ones on the fender are bolted.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
1940 Cadillac 60S Limo
