USA Parts sells the color coded vacuum tubing, and while it is not factory, and only available in the small size, it resembles original better than nothing. I have used the standard NAPA name brand vacuum tubing in the various sizes and it works fine and holds up. Don't use fuel tubing, that does not hold up as well, because it is not really designed to get too hot. It seems much more rugged, but heat is the rubber fuel tube's kryptonite.
Vacuum tubing and devices are vital in these mid 1960-1980's Cadillacs, and have never had a problem using these methods.
