Author Topic: 1942 Fleetwood vin# where is it?  (Read 415 times)
Offline jyinger
  • CLC Number: 26643
  • Name: Jon Yinger
« on: February 10, 2020, 11:33:00 PM »
We have cleaned off the top of the frame from the firewall up to near the radiator--driver's side.  Nothing.  Same thing on the passenger side.  Still nothing.
What are we missing?
Jon Yinger
Offline Jeff Hansen
  • Administrator
  • CLC Number: 4225
  • Name: Jeff Hansen
Re: 1942 Fleetwood vin# where is it?
« Reply #1 on: February 11, 2020, 09:15:51 AM »
Jon,
You will find the serial number on top of the frame rail on the passenger side between the firewall and the motor mount - likely adjacent to the starter.  If there is a lot of rust on the top of the rail or the area has been refinished, the number may be faint.  Please keep looking!  If you have the original engine, the same number will be found on the engine block just above the water pump.
I'm at work currently but can post a photo from the shop manual which shows the two locations this evening.
Hope this helps you.
Jeff Hansen
1941 6019S Sixty Special
1942 7533 Imperial Sedan
Offline Jeff Hansen
  • Administrator
  • CLC Number: 4225
  • Name: Jeff Hansen
« Reply #2 on: February 11, 2020, 07:06:15 PM »
Jon,
As promised, here is the photo from the 1942 shop manual showing the two locations of your car's serial number.  I added the color to the arrows to make them stand out.
HTH,
Jeff Hansen
All Cads
